hi,
i have a block which is 0.64' away from the origin. how do i apply angular accelration in HM ? pls help
Hi Srikanthg2310,
could you please brief about the problem/analysis?
If you want to apply rotational acceleration, you can use RFORCE card which is represented as a load collector.
create a load collector with RFORCE as card image. Edit the same to enter parameters.
Please refer to RFORCE card on help documents for information on how to use it.
