Periodic Mesh utility
Altair Forum User
Hi everyone,
I am trying to mesh a rotationally symmetric sector with same mesh pattern on the end surfaces of the sector.I found out that the periodic mesh utility can be used for this.
But it gives a error when i select the source and target surfaces saying that the surfaces are at a distance of some small value like 0.043.is there any way to increase this tolerance value
or is there any other way to achive this mesh pattern.
If your geometry is not so complicated, you can control that yourself, the utility is not needed.
