Hi I am getting the following error.
'RBE2 184065 187320 0 187321'
*** ERROR # 1000 *** in the input data: Incorrect data in field # 4.
I would appreciate any help I can get. Thank you.
Hi I am getting the following error. 'RBE2 184065 187320 0 187321' *** ERROR # 1000 *** in the input data: Incorrect data in field # 4. I would appreciate any help I can get. Thank you.
field 4 are dofs to be constrained, did you uncheck all dofs on panel 1D-rigids ?
No, I left all dof checked. Should I have unchecked some?
No no, Alec
you should check all dofs normally
and recreate the rigids.
