Hi all,
I would like to know where to put a user menu button macro so that each time hypermesh is started, the related buttons will be loaded in the user utility subpanel?
Thank you
Fatih
Hi, you look for the file userpage.mac in executable path
In Windows, you can make a shortcut on desktop and change 'Start in' to your folder (containing your userpage.mac file). By this method you can have several shortcuts with different user macros.
The same way under Linux.
