my name is Javier and I´m from Spain.
I´m currently the dynamics system manager in Formula URJC ( Formula Student team) and I´m using the templates to design our next suspension system. But I have a problem with the template. It seems like the tire in the template is not 13'' because the wheel centre point is in the 262.64 coordinate in Z axle. We are using Hoosier 13'' wheels and I need to change the body radius, because if I change this coordinate, the only change that appears is in the point not in the wheel size. How could I change the wheel size?
Ok, now I want to take advantage of the opportunity and ask another question. I have already seen the tutorial about how to input a target for the suspension system design, so here is my question:
What happen if I achieve a target with the optimization and then I want to achieve another target but this one may change the first one? Does an error appear? Or does the program calculate a compromise solution?
Thanks!
Javier
