Midsurfacing complex geometry
Altair Forum User
Altair Forum User
I am currently working with fairly large models that consist of a number of parts that are castings.
In order to keep the element numbers down in the model a number of the castings are being simplified using midsurfaces.
The castings that are getting midsurfaced have a large amount of uniform thickness material  whcih is fairly easy to midsurface but they feature a number of more complex areas featuring bosses and varying thickness material that makes midsurfacing very difficult and time consuming.
As the auto-midsurface can not handle this geometry a large amount of manual midsurfacing work is required and this has is very time consuming and frustrating, partly due to Hypermesh not being the most stable platform for creating midsurfaces manually. I have had a large number of problems when equivalencing sides and replacing points where Hyperworks seems to carry out additional, unwanted, actions (eg. toggling 2 edges and it will effect points or edges that I do not want to move).
Has anyone had any experience doing this that can offer me advice or tips? Or is it just a case of being persistent with it?
Will
Welcome!
  • Altair Forum User
    Altair Forum User
    edited August 2013
    Try to divide your model into small block then use auto-midsurface function to extract mid-surfaces.
    Of course, you have to fix some surfaces after. I think surface functions of Hypermesh are powerful enough to do this kind of job.
  • Altair Forum User
    Altair Forum User
    edited August 2013
    Thank you very much for your response.
    I will try using this method.
  • Altair Forum User
    Altair Forum User
    edited September 2013
    hi try to use element offset, first you need to mesh the top surface then offset it with half of its thicknes, the mesh flow will be more prettier than before. Hope this can help you.
Welcome!
Welcome!
