Can we give CONDUCTION and CONTACT(SLIDE) interfaces simultaneously between the elements of two components?
Hi Vij,
Please refer to help for Contact-based Thermal Analysis.
Thanks Prakash sir.
But can you suggest me some tutorials regarding these
For the Contact-based Thermal Analysis you need 2 subcases and couple them.Please refer attached thumbnail for sample tutorial.
In attached tutorial we have used gap elements , instead of that you can define contact and perform contact based thermal analysis.
For more information please refer user guide og contact based thermal analysis. since we have added many new features in latest version of Optistruct.
Regards
Rahul R
Thanks @Rahul R.
But I have defined contact and tried to perform contact based thermal analysis. I gave conduction type CONTACT. But it is not showing any results.
Could you share Updates and system information?(Refer below thumbnail to get info)
Hi Rahul R.
The information that you asked are as follows:
Update Info:
I would recommend to try same in our latest version 13.0
12.0 should also work. Please share your fem file or out file?
Thanks Rahul R.
These are my Files as asked.
https://drive.google.com/folderview?id=0BzUoUlIzK6L0fnl5M2J2OEw0ZnhsUFI5dW9jTjZ0cDJDVExwdFh1Q2NLRnB5RUxkYVY0Q2c&usp=sharing
