How to implement 74HC595 shift register in sT Embed, so that my output is 10100000. How the DATA, CLOCK & LATCH pins are configured?
Hi Athiesh,
You can use a combination of a constant block that accepts a matrix and feed it through to a buffer block. The buffer block could output at every time step and this should do the job.
Please let me know if you need additional help.
Thanks,
Sreeram Mohan
