i have the following Problem:
I created 4 Shells using midsurface. The problem is, after creating them everything looked fine so there were no Surfaces penetrating each other.
When i used the tool Penetration the system told me there were several places (where bolts went trough a shell) where penetrations occurred. After checking the Property Card of the bolts i knew the penetrations with the value 2 happened because of the thickness T i added (which was T=4) So i tried ZOFFS-> SURFACE->BOTTOM which actually didn`t made any difference in the penetration Value of 2. Could anybody tell me how to solve that problem ? Is there a way to shrink the Surface model or is it possible to add the surface thickness to the inside direction of the bolts ?
Greetings
