Hello sir,
please tell me how to Apply 50 rpm rotational motion on a rotating body in motion solve as input
Hi Monu,
I am assuming you have a assembled model.
You can apply rotational motion(displacement) to revolute joints. Use Apply motion option and create a displacement on Revolute joint.
yes sir, i have assembled model and select velocity option on revolute joint but Sir where and how to define the magnitude 50 rpm
@Monu,
Within the motion panel you can enter the value of motion.
I have to apply velocity as 50 rpm, so in property have to select velocity or displacement
and
in value, if I will enter 50 then will it take in rpm automatically.
sorry In my earlier post I posted as displacement. Use velocity in the same motion panel. The value furnished will be treated as velocity.
sir if I will enter 50 in value .it will take unit as rpm or I need to convert this in some other unit
and what will be the initial condition in this case
@monu
In MotionView you define units and I am not sure what unit system you are following. You can find the unit system in Model Browser>> Misc>> Units. If the units are in seconds, you need to convert the RPM from RPS
Please check and update accordingly.
Ok sir
One more doubt Sir for part B in student problem pdf you have given Tstop -0.02s Anim/Dt - 0.2e-4 So it is generating 1000 animation file .is it necessary to generate this much amount of animation file.can we reduce this to 100.
This is not MotionSolve parameter. It is from RADIOSS engine. Please check.
If you are participating in AOC INDIA or any events related to INDIA, I suggest you to write in http://forum.altairhyperworks.com/index.php?/forum/77-forum-for-india-academic-users-and-aoc-india-participants/
