I have some problems when I try to use contour geometry from existing surface in sketch mode. Always when I try to select some lines to delete, Inspire stop to run and close.
Has anyone had a similar problem ?
Hello Marco,
Could you please let us know your graphics card model ?
Thanks,
Matthieu
Hi Matthieu,
I´m using Dell Precision M4800 Mobile Workstation with graphic card Nvidia Quadro K2100M.
I see that this problem happen only when I try to do this procedure in import models. When I made in models created in Inpire this error doesn´t happens.
Marco
We have had issues with older graphics driver for that card. This has been fixed recemtly on NVIDIA's side. Could you please update your to version
and let me know if it solves your issues?
With new graphic card driver the problem doesn´t happens again !
I updated the driver to version 375.86 and Inspire doesn´t open. There is some problem with this last NVidia driver version ?
Hi Marco,
Yes. We are working with NVIDIA on it. Please revert to 369 version of the driver in the meantime.
Do you have plans to run Inspire with the last version ? I have others applications that are recommended to use the last version.
Definitely. Like I said we are working on it.
Ok.
Thanks !!
I am facing the same issue when projecting exisitng lines in sketch mode, and sometimes only by sketching new lines.
I've got a HP Zbook with a Nvidia M2000M graphics card.
Could you help me please?
David
