Composite properties
Altair Forum User
Hi there
I have a problem with assigning PCOMPP (composite property) to certain components. It actually worked fine but when I changed the view to composite layers to see the lay up, only certain components can be seen with layers, whereas the rest are just normal one layer shells. The funny thing is, the entire model has been assigned to the same property but only a few components show the lay up. What could be the problem?
Thanks
Did you end up solving this, or can anyone else help?
I'm trying to view my composite layers, and all I can get is the total thickness of each shell element. No layers at all.
Any suggestions?
Thanks
