Submitted by Joe on Thu, 05/02/2013 - 03:52
I want to burn my Concerto C28x program to flash. I see you recommend Uniflash to burn it to flash, but how the heck do I use it? TI doesn't seem to have very good help.
Submitted by pete on Thu, 05/02/2013 - 04:03.
To create a flashable image, just check the 'Target flash' option on the codegen screen. To burn the image to flash you can use TI CCS or Uniflash. If you haven't already installed CCS, Uniflash is faster to install. You can download Uniflash from TI here. The first time you will need to create a config file like so:
To flash your program do the following:
Next time you open Uniflash, just look for your saved config under the File menu and skip the config file creation.
