Error at Import of an airbag-modell into HyperMesh
muemarc
muemarc Altair Community Member
edited November 2020 in Community Q&A
Hi there,
for my bachelor thesis, I need to add an airbag-model in a existing car-model. But when I try to import the model I always receive the error: Error reading from feinput process.
I started wondering myself, if the model, which is a .xml Madymo-file, is compatibel with HyperMesh, or if there are other mistakes?
The file is attachted to this request.
Thank you very much for your help.
Kind regards,
Marco Müller
  • Altair Forum User
    Altair Forum User
    edited July 2018
    Hi muemarc,
    Which version of Madymo solver you are using?
    Thank you
  • muemarc
    edited July 2018
    I am using the Madymo70 solver.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    Hi muemarc,
    Which version of HyperMesh you are using? Did you trying importing this file in 13.0 or older versions? In the current versions i don't think Madymo .XMl files are supported.
    Thank you
  • muemarc
    edited July 2018
    Currently I am using the 14.0 version.
    Thank you very much, I will try it on older versions.
  • muemarc
    edited July 2018
    I tried to import the file in several different versions, but I always receive the same error message.
    Do you maybe know that else could be the problem?
    Thank you very much.
  • Altair Forum User
    Altair Forum User
    HI @muemarc
    From the Madymo file I can see that you are using a V7.4 release
    This may not support in the current version of HyperMesh. In HyperMesh, we support till V 7.0
    You can change the format in text editor to import the file. I made changes to the file and here is the attached,
    But export may not be possible as some entities are not supported.
  • Altair Forum User
    Altair Forum User
  • muemarc
    edited July 2018
    Thank you very much for the quick reply.
    The error message doesn't occur anymore, but instead a window pops up with the message:
    A segmentation error occured.
    Do you want to save your model?
    Best regards,
    Marco Mueller
  • Altair Forum User
    Altair Forum User
    edited July 2018
    Can you delete the setting files and try again?
  • muemarc
    edited July 2018
    Yes, but I still get the same result.
    Thank you
  • Altair Forum User
    Altair Forum User
    edited July 2018
    I am able to open the same in 2017.2 but in 14.0 I have the same issue.
    Can you update to 2017.2 and check if that helps?
  • muemarc
    edited July 2018
    Awesome it works, thank you very much!
    For my bachelor thesis I now have to implement this Madymo airbag-model into a LsDyna car-model. Is this possible?
