Creating RBE3 element with 1946 independent nodes
Hello all,
I am trying to create rbe3 element with 1.0 weight to independent nodes , however, following code generates 0.0 weight for independent nodes.
my tcl code is ;
*createmark nodes 1 'by sphere' -341.255 -75.946 6.482 0.25 inside 1 all 0
*appendmark nodes 1 'by face'
set rbl [hm_getmark nodes 1]
set nrbl [llength $rbl]
for {set i 0} {$i < $nrbl} {incr i 1} {
lappend dofl 123456
*createarray $nrbl [puts $dofl]
lappend wgh1 1.500000
*createdoublearray $nrbl [puts $wgh1]
*createnode -341.761 9.994e-02 1.549 0 0 0
*createmark nodes 2 'by sphere' -341.761 9.994e-02 1.549 0.2 inside 1 all 0
*rbe3 1 1 $nrbl 1 $nrbl [hm_getmark nodes 2] 123456 0
At the end of the day, I want to generate following RBE3;
Hi Merula,
Tank you for support. I have developed following code based on your suggestions. Finally it works /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />.
Hi Tinh,
Thank you for your help.
*clearmark nodes all
*appendmark nodes 1 'by sphere' -341.252 76.398 -3.898 0.25 inside 1 all 0
set nrbl [hm_marklength node 1]
set dofl [lrepeat $nrbl 123456]
set wgh1 [lrepeat $nrbl 1]
eval *createarray $nrbl $dofl
eval *createdoublearray $nrbl $wgh1
eval *rbe3 1 1 $nrbl 1 $nrbl [hm_getmark nodes 2] 123456 1
*nodecleartempmark
Hey,
as help says:
*rbe3 mark_id independent_dofs dof_size independent_weights weight_size dependent_node dof weight
the last parameter is the weight, which is zero in your case.
If you bother, here is my way of creating rbe3:
eval *createmark nodes 1 {'by box'} [expr $x-$delta] [expr $y-$delta] [expr $z-$delta] [expr $x+$delta] [expr $y+$delta] [expr $z+$delta] 0 inside 0 0 0
hm_createmark nodes 2 [expr $nodeId]
*markdifference nodes 1 nodes 2
set numberOfNodes [hm_marklength node 1]
#Arrays
set arrI() [lrepeat $numberOfNodes 123]
set arrD() [lrepeat $numberOfNodes 1.0]
eval *createarray $numberOfNodes $arrI() ;
eval *createdoublearray $numberOfNodes $arrD();
eval *rbe3 1 1 $numberOfNodes 1 $numberOfNodes $nodeId 123456 1;
Best regards,
Merula
