Export STL mesh in Hyperworks
I am using the HyperWorks 13.0 Student edition and I created a mesh on a geometry. I would like to export the mesh as a STL file. Under Export Solver Deck I only get options for OptiStruct, RADIOSS and CFD. There is no option for STL. How can I export the mesh as a STL? Or is it not possible with the Student Edition?
This is not possible in Student Edition.
However, in full version, it is possible by doing the following:
Tool => faces => select your solid elements to create faces.
Then Export => Solver Desk => STL as File type => You got your STL file.
Student edition has a limitation on export formats.
As a workaround you can use sT Inspire.
Import the geometry into Inspire and you can export that to .stl file.
What is the use case BTW?
