When Hyperstudy is invoked from within Hypermesh (CFD Acusolve profile), in the option window that opens, in the dropdown for the response parameters, I can see only pressure as the option. How can I use a different response parameter? For instance, if I am trying to optimize the mass flow rate, my response parameter should be mass flux. Am I right?
Can this reponse parameter be changed later in Hyperstudy?
Also, assuming if I did a preliminary setup in Hypermesh but I want to use a different INP file than what the Hypermesh setup is, is it possible to do that?
