Is there a way to update results in all windows in Hyperview?
I am post-processing many sets of results data in Hyperview (20 sets per h3d results file, and multiple h3d files). I have 7 pages with 2-4 Windows per page. I want them all to show the same results set. Right now I need to go into each window and update the results set, and do this 20 times per result, and I have dozens of results. I then need to go through and export photos for each page, and it becomes time consuming.
Is there a way to: update ALL windows to the same results set and export ALL plots to PNG files. Also, since I have multiple H3D results files, if there is a way to point all windows to the same file that would be great as well. If I can run this in batch, that would be best, but anything that cuts down on the number of clicks would be helpful since the plots are standard and just need the new results loaded before being exported.
I did find the synchronize windows button but that just synchronizes the view, not the results data.
I appreciate any help you can give!
Did you tried Synchronise animation under tools pull down menu. See attached screenshot.
Regards
Rahul R
