Can someone please tell me if there is a way to view the deformation and displacement of a section of a model on hyperview? I want to see the deformation in a certain section of a cylinder.
Thank you in advanced
Kind regards
Please refer attached pdf from HyperView online help.
Thank you Rahul.
Hi Rahul,
I created the sections, now I would like to know if theres a possibility of measuring the displacement of the section cut because it deforms as well when i run the simulation. I cant find the instructions to do that on your tutorial. I am able to visualize the undeformed shape using the deform panel so there must be a way to measure the difference between the two. Is there?
Please refer HV 5020 tutorial.
