Hey Guys,
I had problem several times in the past with the 3D tetrameshing. My mesh on the surface is pretty good, you can see the mesh criteria file settings on the attached picture, but my 3D tetramesh isn't good enough. There was error during element check. (I know I can turn off element check, but I want to make a good 3D mesh).
Therefore I would like to ask guys, that give me a criteria file, that will be good enough for 3D tetramesh.
Thanks for your advice in advance!
