I can't see created mesh
Hi. I'm beginer in hypermesh.
I installed hyperwork in my local computer today.
Then I performed making a mesh but I can't see mesh element.
I do same thing by same process at another cumputer witch has been installed hyperworks,
however, I can see all of the mesh.
So I was trying to solve this problem several option but.. I couldn't find anything.
Please let me know If you have some idea to solve this problem.
Thanks.
Hi Prakash.
Thanks for your answer. But I already checked that.
do you have any Idea?
0 -
Hi Maul,
Can you check the elements option for all component collectors and see whether elements are visible.
Also, from mask panel, 2D and 3D option click on + option which will show the elements in the model.
If the issue still persist, please open the file attached along in HyperMesh and let us know whether you are able to see the elements in this model.
0 -
Thanks.
Hi
Try installing hw13. Newer versions may not be perfect. Could you show your graphic card details?
0 -
I really appreciate your answer.
Finally, it was fixed. It was my computer problem with graphic card.
I installed newer vision driver of graphic card. And then I can see all of mesh.
Thank you!! Guy!! lol
