Assigning Media to Regions and Faces
Why can I not assign all the media I have added to my Media Library to the regions and faces of the objects in my FEKO models? What are the rules for assigning media to regions and faces of models? I was told in an email from the FEKO support team that a metal solid is modeled in FEKO not by setting the region of the object to a metallic medium (which is not allowed) but by making the region medium of the object free space, by making the medium of the object 'surfaces' (by which I assume was meant 'faces') the needed metallic medium, and by making the thickness of those 'surfaces' greater than skin depth. I have tried this but the metallic medium I am using, copper, does not appear on all of the model faces I need to model as copper. I am using FEKO 7.0.
Hello riiily,
Firstly, I would suggest that you upgrade to the latest version of FEKO. The latest version if FEKO 2017.1.2.
The information provided by support is correct and this 'strange' way of setting the media comes from the original solution method used in FEKO - the method of moments (MoM). The MoM models (usually) only the surfaces and thus all settings are set on the surfaces (or faces). If you want to model a copper cube, you model the faces of the cube as copper, but you then also need to supply the thickness of the faces since this is not available to the solver.
Without seeing the model, I can only speculate as to the reasons for this. If you have set all the regions to free space or a dielectric, you should be able to set the faces to a lossy metal (such as copper). If a region is set to PEC (or Default, that evaluates to PEC for that region), then you will not be able to set the faces to lossy metal.
If that does not help, I suggest you provide the model and the face that is not working the way you expect and then I can have a look.
