Someone knows how to solve this problem?
Thanks!
Mizquierdo,
It means the wheel center marker is constrained in a way that it is not allowed to move in a certain direction.
MotionSolve K&C analysis is trying to calculate the various parameters and it needs to determine the force required to move the wheel center in a specified direction.
In your case it appears the wheel center marker cannot move in the y-direction. You can search the MotionSolve input .xml file to find which wheel marker #20703020 is attached to.
Have a great day
