Hello everybody,
I am from Chile and i am trying to setting up a simulation that could run an acusolve-EDEM coupling and the fenomenom is described next:
I need to simulate how bulk material whitch is falling in to a chute are mixing with a portion of water (agua) who is added by a pipe in the midle of the chute and review the next points:
.the cohesion effects due to the mix (zona de mezcla) between water and bulk material
.the wear in equipments due to the impact of the bulk material
.the duct blockage at the end of the chute due the mix (water-bulk material)
Is necesary to understand that the chute never will full of water, the water will run into a little portion of the control volume.
