Use particle radius in Particle Body Force API
User: "Yangyang_Shen"
Altair Community Member
Updated by Yangyang_Shen
Hi. I'm writing a particle body force API that needs to use particle radius in my calculation: Y = A * particle.radius + B;
But when compiling, I get the error: class "NExternalForceTypesV3_0_0::SParticle" has no member "radius"
So particle.radius is not in the function namespace NExternalForceTypesV3_0_0.
Can I include particle.radius, similar to other properties (i.e. mass, volume) ? See screenshot below for the new line in the red box.
1 - 1 of 11
    User: "jerrinjobs"
    Accepted Answer
    Updated by jerrinjobs
    Hi Yangyang
    It is highly recommended to not change the header files for the API. You can use the volume information of the particle, and calculate the radius from it.
    radius = pow (3.*particle.volume/(PI*4.),1./3.);
    Hope this helps.
    Thanks,
    Jerrin Job
