good morning,
It is possible to export the final animation file as step, in order to check the quote?
tank you in advance
Federico
are you referring to exporting the final step of animation in step format. or export the video only for final step.
you can use the animation start and stop slider to control the animation. the exported Avi file will only have the steps you have requested for.
i mo refering to export the final step of the animation in step format...i is possible?
I see option to export as solver deck is available.I dont think we have option for step.
STEP is CAD exchange format.
Why need export 'results animation' as STEP???
Can't understand what do you want.
So if @fedescu wants to export to stp format, he's just using this deck to generate surfaces (geom>surface>from FE), and export these surfaces as stp file
