How to assign a value to customer particle property
User: "Yangyang_Shen"
Altair Community Member
Updated by Yangyang_Shen
When writing an API, I know how to take the value from a customer property using the getValue function. My question is what function to use to assign a value to a customer property, while the value is calculated in the code?
For example below, I use the "Particle Pore Filling" to calculate the "Particle Moisture".
      const string CComputation::PARTICLE_POREFILLING = "Particle Pore Filling";
      const string CComputation::PARTICLE_MOISTURE = "Particle Moisture";
      const double* elem1PoreFilling = elem1PropData->getValue(PARTICLE_POREFILLING.c_str());
      double elem1Moisture = *elem1PoreFilling * elem1Mass;
Then I want to assign the value of elem1Moisture to the PARTICLE_MOISTURE customer property. How can I do this?
Any advice will be much appreciated!
