The following is the vonmises stress contour plot i get in a component with predominant bending load.
https://drive.google.com/file/d/0B2rIYPnVjYNEVjdfcHNQTjBXNVE/view?usp=sharing
I get discrete distribution concentrated at each elements. (I used 10 noded tetra). What could be wrong here ?
Hi
Anyone please clear my doubt.
Ahilan A
Hi Ahilan,
can you share the files with us?
use the dropbox link in the below signature to share the files.
Hello Prakash,
Filedrop is not working.
Is it ok if i upload in a external server (Google drive) and share ?
Please try with the below link:
https://ftam1.altair.com/filedrop/~Ce4god
What is the version and updates for HyperWorks do you have?
on HW 13.0, I can see a clean contour with HyperView.
Thanks for the reply.
I use HV 12. So the problem is with the version.
Maybe not.
Even with 12.0 110 update, I get the same result.
can you update the 12.0?
VIsit the link below for more details on updates.
http://www.altairhyperworks.com/ClientCenterHWUpdateDownload.aspx?pro_cat=HyperWorks
