Hi. I want add a particle custom property that is calculated from the particle temperature. And I took the heat conduction API code in the example 'HeatConductionForGeometry_29July2014.zip' from the page link below:
https://community.altair.com/community/en/edem-api-contact-model-example-heat-conduction?id=kb_article&sysparm_article=KB0121824
The new custom property, PARTICLE_CONTENT, is a mass property. The PARTICLE_TEMPERATURE and GEOMETRY_TEMPERATURE are from the heat conduction code before.
const string CHeatConduction::PARTICLE_TEMPERATURE = "Temperature"; const string CHeatConduction::PARTICLE_CONTENT = "Content Particle"; const string CHeatConduction::GEOMETRY_TEMPERATURE = "Temperature Geometry";
And I defined PARTICLE_CONTENT as below:
if(eParticle == category && 0 == propertyIndex) { strcpy(name, PARTICLE_CONTENT.c_str()); dataType = eDouble; numberOfElements= 1; unitType = eMass; return true; } I was able to compile the code, but when I tried to load the library file in EDEM, I got an error message:
For my simulation, I only selected 2 inbuilt models (Hertz-Mindlin with JKR, Standard Rolling Friction) for Particle-Particle and Particle-Geometry interactions. Also my EDEM deck was created from scratch, so I don't think there's any previously used custom properties.
Can anyone please help me figure out what I have done wrong?
Thanks a lot!
