I was wondering if there is a possibility to open the results of a FE analysis with another program other than hyperview. Or if it is possible to export the results file with contour plots to an 3d pdf or somthing similar?
thanks,
diego
what is the objective of exporting output in pdf? are you aware of Hyperview player?
Yes, Hyperview Player is your (best) solution.
Just export your results into H3D format and use free software 'Hyperview Player' to visualize.
