Hello
I actually work in SPH and I would like to create pressure graphs with Hypergraph.
Usually, in hyperwork, to have this kind of data, you put pressure sensor into element, which is logic since you make pressure calculation in a volume. But, when you visualize results with HyperView, you can see the pressure evolution, so it should be possible.
But, in SPH, there is no element, only nodes. So how can I input pressure sensor into hypermesh, to be able to view them with hyperGraph, after a radioss calculus ?
So how or which sensor do I need, where to get it, or which modification should I change in the 0000.rad to be able to have those graph under hyperGraph2D in SPH model
Sorry for any poor english, I am french, thank you very much in advance
Regards
