good morning,
when i add a material to radioss one step and run the analysisi, it display an error message '3 fields exceeded field lenght' which could be the problem?
thank you in advance
Federico
While defining mat prop you get this error or after run?Please share update and system information of Hyperworks you are using.
i get this error after run, i m using HW 14
Could you share out file of the run?
Hi Federico,
It could be an issue with length of the input value you have given.
Find out which values they are from .out file and try to reduce the length of the number.
