Altair RISE
Nominate Yourself Now!
Estimating Y+
User: "Altair Forum User"
Updated by Altair Forum User
What is the length scale, coefficient, power in the Y+ Estimator. What are required values ? How to find the Y+ ?
pls see the attached screenshot
<?xml version="1.0" encoding="UTF-8"?>post-30317-0-38226300-1394610558_thumb.j
<?xml version="1.0" encoding="UTF-8"?>post-30317-0-85429000-1394619317_thumb.j
1 - 3 of 31
    User: "cfdguru"
    New Altair Community Member
    Updated by cfdguru
    The screenshot you are showing represents a user defined relationship for estimating the y+ in AcuConsole.  If you click on the 'Whats this' icon in the main toolbar, then click on the 'Power' entry in the panel, it will show the equation that is used to determine the Y+ for this use case:
    Y+ = (Y1/coeff *Len) * Re^power
    Y1 = first layer height
    coeff = Coefficient
    Len = Length Scale
    power = Power
    The Reynolds Number is estimated based on the material properties supplied by 'Material model' and the length and velocity scales.
    Note that the 'Estimated Y+ method'=User is typically only used if you are working with an application for which the 'Flat Plate' and 'Pipe' relations don't work well, and you know the proper scaling.  In my experience, the predefined approaches are pretty good for most applications.  I use 'Pipe' for internal flows and 'Flat Plate' for external flows.
    <?xml version="1.0" encoding="UTF-8"?>post-4412-0-21318900-1394624604_thumb.pn
    OP
    Thanks guru for the reply image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'> I'm doing external aerodynamics, So I think I can stick with the flat plate as you said. But  I'm still curious to know what  the power & coefficient are related to materials - like air ?? I mean its the power & coefficient of what ???
    User: "cfdguru"
    Updated by cfdguru
    No problem!  The power and coefficient would be related to the geometry of the simulation.  Basically, it's there for users that have complex applications for which they have developed their own relationships between Re and Y+.  So, it really just serves as a general expression that you can tune to your specific application.
