@Rahul Ponginan,
Hi, I try to use click2cast and I got an error message : 0 Undefined error.
What should I do with this case?
I attach the error file
Thank you
Seems the solver is blowing up and this might need development help. Please contact your local Altair support and send them the files from the run folder as zip.
Hi @ydigit,
Thank you for your response....
The problem has been solved, but I don't know why it could be happen....
I just change my mesh size to solve this problem...
Best regards,
Iron_Man
