Hi All,
I am receiving an error when I go in to OptiStruct suggesting that I am missing a property reference for about 5000 times.
I have assigned a property to the components that require one.
Thanks if you can help.
Hi All, I am receiving an error when I go in to OptiStruct suggesting that I am missing a property reference for about 5000 times. I have assigned a property to the components that require one. Thanks if you can help.
Hi
how can we believe that you assigned it?
enter menu Tool>model checker to find what's wrong
or send us your model
David,
Maybe assigned property is not compatible with element. Make sure you did assigned solid (PSOLID) to solid elements and shell(PSHELL) to shell elements.
If there are any unused shell/solid elements which are not required for analysis but used for modelling, check and delete the same.
