Hallo,
I tried to defeature surface fillets of a complex part (with around 3000 FILLETS). But all the surface fillets are not removed Some surfaces failed to connect and a lot free surfaces and edges are formed.
How to defeature these Fillets.
Hi.
Have you tried defeaturing surface fillets based on radius?
Please try that, if not did so.
Hi
if fillets are simple then it is possible
but in complex geometry usually we have fillet in conjunction with others so not all of them can be defeatured
so you see lots of free edges
manual mesh may need in this case
