How to apply uniform varying load in hypermesh ?
Hello ravi,
For example consider load is varying from 1N to 10N on a cantilever plate <?xml version="1.0" encoding="UTF-8"?>.
In that case you have to create two forces of 1N and 10N at the end of the load region.
Go to> Analysis> Force>
Under Global coordinate system change the load type from 'Constant vector' to 'Linear interpolation' as shown in the figure .
Regards
Raviteja
Hello Raviteja,
first i have created 2 loads at the ends shown in images
Analysis> Force>
Under Global coordinate system change the load type from 'Constant vector' to 'Linear interpolation' > fill gap option is not shown
For web usage (like this forum) try to use JPG or PNG when you posted your pictures.
Helllo ravi,
I am using hm12 may be you are using some lower version.
If u didn't get the distributed load, just increase the search radius more or less equal to the distance between the loads that you want to create the distributed load.
ok, Mr. Q.NGUYEN-DAI
Thankx
