Tetramesh
Updated by Altair Forum User
Dear all,
I have a problem with the aftermath of tetrameshing. I have two different parts which can be imagined as a hamburger. The outer layer is bread and the inner layer is beef. I have to tetramesh them into two different parts so that I can assign different material properties to them respectively. But when I tetrameshed the parts one by one, they will end up with only one tetramesh model. How can I separate them into two different tetrameshed solid parts?
Your help is greatly appreciated and thanks in advance.
Kind regards,
Mushi
1 - 2 of
21
Hi Raviteja,
Thanks a lot. Indeed it helped me solved the problem. Help appreciated!!!
Hi Mushi
You can use Tools >Organize option to move the elements from one collector to another.
Or
Press SHIRT+F11,,.. select the elements you wanted to move and specify the destination collector select MOVE
I think this will help you
