Hello sir,
Is it property required for spot weld connection?
Which property select for connection?
Waiting for reply
Thank.
A property is required for the connections. Like, if you are modelling connections with springs you have to assign a spring property.
But if you are modelling with rigids there is no need to assign any material/property.
Please go through https://www.youtube.com/watch?v=fNc9oVVkBa8&list=PL1u26y75SCrA_BOCLaSewVCNY7xRvCTnA which shows modelling connectors in RADIOSS profile.
