Hi, i would like to know what is meant by the condition Ztrac (that in my simulations I set 0MPa)?
Can you also explain to me what is the slip velocity friction?
When you specify Z(traction), it means that material can slip on Z direction.
Spli velocity - information is available in help document. If you need more information then let us know.
