what is the use of dummy ply?
Hi Chaithanya,
Do you mean dummy property?
PCOMPP is a dummy property allow handling laminate modelling.
If you see the Create Ply dialogue box ,there is a check box for dummy ply.I was wondering where is it used ??
Also PCOMPP is used as dummy property for Zone based modelling.It is actually in use for Ply based modelling.Is my assumption correct?
1) The below image should answer your query
2) Yes, PCOMPP is used a dummy property to convert a ply based model to zone based using the Realize option.
Thank you.
Where can I get a comprehensive guide for composites using HW suite.
See http://training.altairuniversity.com/analysis/structural/composites/
http://www.altairuniversity.com/free-study-guide-book/ the student guide
HI Rahul,
I am looking for composite setup for Nastran,Dyna,abaqus solvers.
