How to simulate Artificial Magnetic Conductor (AMC) along with the substrate using periodic boundary cell (PCB) in FEKO?, i already try follow the example simulation of fss design ( inside example guide feko), but its totally difference because i need to see the result reflection phase.
   	Before this i using others simulation software, I also attach the example of the design with the result, i should get the same result..
