Hyperstudy
User: "Altair Forum User"
Updated by Altair Forum User
I am doing some vbration study in optistruct.For that i need some parametric optimization in hyperstudy.
I have created features and parameters in hm and if i change the length in parameter it is updated in geometry and 2d shell tria mesh.
But 3d mesh will not updated.
I need it because in hyperstudy the source file is hm file
Is there any other way to do the same
1 - 3 of 31
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Do the Shape Parameterization in HyperMorph.You can refer below tutorial from help.
    HS-2000: DOE Method Comparison: Arm Model Study
    OP
    Hi Rahul,
    Thanks for your reply,
    But ,I have some doubts in creation for tpl and also it is complicated since it is node based,I think so.
    Below is my simple need.I need 3d mesh automatically.Since i am using hm file as source file not parametrized  file.
    I have set some parametric based feature(Geometry) on that hm file.
    Say for an example,
    If change some length the feature is automatically updated in geometry and so on the process. HM options parameter and feature.
    <?xml version="1.0" encoding="UTF-8"?>Capture.thumb.PNG.a8b5b30ced3a944821d4f56ead35bb1f.PNG
    India support team is working on your query.I will add final outcome of the query once it closed.
