Hi all,
I have a problem with CFD tetramesh using HM 12.
I'll describe you a simple example that explain my problem.
I have to mesh 2 volumes sequentially, with an 'internal' surface that separate them.
Some surfaces of the first volume are set as with BL fixed , one of them is set as without BL float.
The first volume mesh is successful created by HM, setting the internal surface as without BL float.
Then, if I try to mesh the second volume, setting the internal surface as without BL fixed and other
surfaces as well as the first volume, HM tell me: mesh is not enclosed.
This problem doesn't appear if all surfaces are set as with BL fixed.
Has anyone found this problem and a solution to achieve my goal?
Thanks
