when i am importing a ls-dyna deck to hm and have *PART_INERTIAs present, i always get the following warning:
'Warning: IRCS value for PART id 11000002 is changed from 0 to 1 i.e the inertias are changed from Global to Local axis and also aligned to the principal axis'
I do not want this to happen... how can i change this, so that hm will not modify the inertial properties at all??
