Windows 7 64-bit
Inspire 2014 build 3966
Following the tutorial 'Moving and Snapping', STEP 1, Sub-step 7
It calls for me to select a group of X_T files and drag them into the Inspire Window.
But nothing happens. No parts appear.
(YES, I did select a 'fit all'. No parts. And no icons show in the model browser).
However, I CAN get the files added to the tutorial and continue, by using the pull-down menus:
FILE - IMPORT (Ctrl-I)
Conjecture:
This computer is not a CAD virgin, has several other CAD tools registered, so perhaps the install script did not register the X_T file extension as possibly applying to the Inspire application.
I have no urgent need here - no need to follow-up with me.
But a Tutorial sequence should be bullet-proof. Either re-write the tutorial, or investigate the install script to see where this could go wrong.
No need to attach files - I am simply following the tutorial.
