i have a problem to import .fem files in Altair Hyperworks 2017 student Edition 64bit .
please give me solution what can i do?
thanks
Error message?
error message - the file is being opened for reading does not exist. no content are show.
This error can occur if the working directory is set incorrectly.
To fix this issue please follow these steps: 1) Right click on the shortcut icon of HM that you usually use. Select properties. 2) Select the Shortcut tab if not previously selected. 3) Confirm that the directory listed next to 'Start in' is a valid directory. If not, please enter a valid directory. The default is '%USERPROFILE%\Documents' without quotes. %USERPROFILE is an alias for C:\Users\<your_username>. Check the attached image for your reference. 4) Press OK. Re-open HyperMesh. If the working directory is set incorrectly, HyperMesh will not be able to create and use settings and log files which can cause this error.
This should hopefully fix the problem.
My hypermesh setting is correct pls give me another solution and thanks for this solution.
HI,,
Please delete all the settings files and try again. Make sure that all the HyperWorks sessions are closed and then delete the settings files.
The below post shows deleting the settings files:
Please share the file if this solution is also not helping, so that we can try from our end.
