Hello everyone!
I want to create midsurface by offset the surface.but How to keep the original one, and create one more?
In the 'Tools' Page you can use the 'Translate' panel and select the surface option. When you click on the 'surfs' option please select the 'Duplicate' option and also select the surface you want to translate. This will keep the original one as well as create a new one.
Thankyou
Hello, In the 'Tools' Page you can use the 'Translate' panel and select the surface option. When you click on the 'surfs' option please select the 'Duplicate' option and also select the surface you want to translate. This will keep the original one as well as create a new one. <?xml version="1.0" encoding="UTF-8"?> Thankyou
Thank you for your help! I got it!
