Dynamic deformation at particular nodes
User: "Altair Forum User"
Updated by Altair Forum User
Sir,
  By default, in measures I see dynamic mim/max option to see deformation of nodes having min/max deformation magnitude at the LAST STEP of simulation which can show their deformation values progressively with the simulation steps.
However, how can I get the dynamic deformation values of particular node of interest, no matter whether it is having maximum or minimum overall deformation?
1 - 4 of 41
    OP
    You can add a Measure group and include Node(s) of interest to that Measure group. See the image below:
    OP
    Sir,
     I couldn't see that option in my case.
    Even after applying the contour plots (not done while taking the above snapshot)
    OP
    Soumitra,
    Plot the contour first, then go to measures panel and click the node of interest.
    OP
    Soumitra,
    Solved!
    Thank You Sir
