I'm having trouble exporting meshes from HM as Marc 3D input decks.
Despite checking the box 'Export in extendet format', a standad marc-file is created, which is limited to a node-ID field length of 5.
Exporting a mesh with more than 100k nodes leads to fields exceeding the field length, which results in a broken file.
Is there a way to sucessfully create a marc-file in extended format (node-ID field length of 10) for larger meshes?
The problem initially occured with HM-Version 12.0 but is still not solved after updating to Version 14.0.
Kind regards
